Tivù said:Angles, eh?
Does the dish have an offset arm? I'm sure it will have ................. don't forget to take the offset angle into account when adjusting the elevation. A standard error is to assume the dish face should be elevated to the target figure.
Tivù said:Dish face should be vertical (by eye) as a starting point .......... then slowly (very slowly!) alter azimuth only until you hit a Satellite >>> Scan then check Channel names to determine which Satellite you've hit, then you'll know which way to move it to the true target, both in Az and El.
Oh, and if you're using a squawker, the cable stub they come with is usually of very poor quality and you'd be advised to make up one of your own to prevent poor connections or even short circuits (owing to the ease with which the centre core can be displaced)
hdp160 said:As Tivu stated first attempts usually have the dish pointing to high.
You have the LNB powered? ( you have seen something when it was held at your other dish prime focus .. yes?)
Captain Jack said:What else are you trying to lock?
Tivù said:For 19E you'll need to raise the elevation a couple of degrees, for 13E a tiny bit more.
Rolandh said:Do I leave the dish pointing in the same direction as 28e or move it slightly?
Roland
Captain Jack said:You have to move the dish slightly to the east - 19.2 East to be exact and 13 East respectively![]()
pgh13 said:I think he means slightly to the West..... If you standing behind the dish that's a little to the right
Tivù said:Foxsat Transponder lists are way, way out of date.
Go to Flysat and choose a target TP then scroll to the end of the Foxsat TP list to "User" and entr the new (and correct!) TP. Then just scan that.
Foxsat's are not that easy to use for setting up a system - ok once you've got to grips with it, but not for setting up.
