master codes for SR650
DeepDiver
DeepDiver
Vista- DreamBox 7020Si Nabilo Darkstar II -7025+ Black Hole 0.11 - DM8000 BlackHole 0.11
Mariana Trench - Pacific Ocean
Did anybody manage to use master codes for StarSatX650CI Super ?
If yes, how?
N
nhfs49
Starsat,Strong, Onyx, Omax, Astrasat, Condor, Starcom, Astrovox, JTAG.
Laptop,Desktop.
Lebanon
dear please try one of these: 1631 or 9876
DeepDiver
DeepDiver
Tnx,
but I am afraid I am doing something wrong....what's the right procedure step by step ?
Tnx again
N
nhfs49
Laptop,Desktop.
Lebanon
Please tell me what's the problem to tell you the answer if i know :-)
maybe you had typed a number by mistake!?
DeepDiver
DeepDiver
Hi nhfs49,
and tnx for support. I must I am a newbie, and thought master codes would allow to see scrambled channels.....:D ....but I have now realized tat master codes give access to the page where keys are, to be edited.
Well, on SR-X650CI Super, I believe you do not need master codes, as on the installation menu, the "Input Code" option allows to edit hex keys....
Many many tnx again.
L
linax
[/QUOTE]Hi, nhfs.
Can you give me an available keys for SRG- SUISSE, and the steps to put them in my IRD ?
I want to see that it WORKS REALLY
Other thing : ho to be sure that the appropriate ID exists in the IRD ?
Thanks a lot...to learn you next
Lina
N
nhfs49
Laptop,Desktop.
Lebanon
dear linax,
1-visite http://www.rdi-sat.com/viaccess.php and write down codes of SRG
2-choose a SRG channel (In General channel that you want to open)
3-Press on Pause from your remote control
4-A box will appear, write the ID 00 94 00 (SRG)
5-write keys without any space
6-save your work
L
linax
str_rof said:
Use The Key
9876
HOW TO BE SURE THAT ENTRED KEYS WERE BEEN SAVED? BECAUSE WHEN I FINISHED, THERE IS NO CONFIRMATION MESSAGE FROM RECEIVER...USELY, I TOUCH "MENU OR ESCAPE" KEYS.
L
linax
IF THIS WILL BE INTERESTING....
Hidden Function Codes
The list of codes to activate hidden functions in Arion based receivers.
For f/w with EMU function to activate it:
1. Go to menu. By pressing menu on your remote
2. Key in : 19370
3. Key in pin: 2486
Now in menu – games, you shall see emu-keys section, should you wish to alter the keys manually, you need to enter pin 0000.
If you forgot the pin you had entered, press 0786 to reset it and enter menu or blocked channels.
Other Codes to be entered when tuner is in stand by mode.
42114802500 – Full information about your tuner (h/w & f/w)
24680 – Uploading keys (irk) or channels list to the receiver.
74621 – Downloading channels list from the receiver.
74623 – Downloading full set of keys from the receiver.
74620 – Downloading f/w from the receiver (AUC_HEDIT).
14802 – Downloading boot from the receiver (AUC_HEDIT)
14809 – Downloading full f/w with boot from the receiver (AUC_HEDIT) – you get “universal” f/w this way.
Test codes:
42125
42126
42127
__________________________________________________
To connect your PC to the receiver, you'll need null modem RS 232 9-pin cable:
1+6---->4
2------>3
3------>2
4---->1+6
5------>5
7------>8
8------>7
How to receive the STB Data from the STB to PC.
NOTE: Receive indicates that transfers the existing data (STB Data) from the STB to your PC; whereas, Send indicates that transfers the added or modified data from PC to the ST:cool:.
1. Choose the "Receive" menu from Main Menu or Toolbar.
2. Turn on the main power of STB.
3. Press special key-code "74621" in the STB stanby mode.
4. The STB Data will be transferred automatically, with a window indicating the process status. (If you wish to abort receiving process click 'CANCEL' button.)
5. When finished the receiving process, click the 'OK' button and then an active window will appear your received data. Please save the data with specific name using "Save As" menu.
How to send the STB Data from PC to STB.
1. Choose the "Send" menu from Main Menu or Toolbar.
2. Turn on(reboot) the main power of STB.
3. The STB Data will be transferred automatically, with a window indicating the process status.
If you wish to abort sending process click 'CANCEL' button.
AF1018SE, AF2018SE, AF3018SE, AF4018SE AF5018CI s/w upgrade
Upgrade procedure
1. Power off receiver.
2. Connect PC and receiver using a serial cable.
Receiver should be power-off state.
3. Execute "ARIONER.EXE"
First, Select proper PORT. ex) COM1 or COM2
4. Click the "Open" button and select "ADA2030SE.auc".
Click the "Send program to IRD" button.
Then, typically "Last status" shows message of "Waiting connect request ack".
Now PC are ready to transfer.
5. Power on receiver
upgrade process will be automatically done in a few seconds.
You can see the progress with PC and/or receiver.
NOTE
When receiver shows "Saving" message, you have to be very careful.
Never power off during this save time. It couldn't reboot and
you have to send back the receiver to us.
At the end of the process, small message window at PC will appear.
Please don't care about the message.
Click "OK" button to clear the message.
Receiver reboot automatically. Check front display of receiver.
If it shows "----" or any channel number "xxxx", then successful.
AF8018UCI s/w upgrade
1. Press “24680” in standby Mode
2. You can see “AIT” on the front panel
3. Open the file “***.U01” by using PSLoader
4. Then you can see POPUP menu to ask to open another file
5. Then, select the file “***.U02”
6. The selection order of files must follow up.
7. S/W upgrade will be done automatically.
8. After completion of upgrade, the receiver will be rebooting automatically.
B
byte_sniper
I HAVE KOSCOM 1600 FTA I SEARCH HIS CODE PLEASE CONTACT ME BYTE_SPIDER*YHOO.FR
M
momma_art
HI,
I want change a boot for pwersky ps-8210cisk.
Hardweare Vertion:ps-8210cisk
Software Vertion : $TSTE1720S821CISK
Database Vertion: 00600009
Boot Vertion : 0011.1
Thanks.
