matrix reloaded cam problem?
BOOTIFUL
CAM
I have a problem with MR cam.I put Matrix reborn software on it.
And now I cannot get it work.It does not read it using a pcmcia interface in the Pc.
Usually says it a dream cam and using loader v1.3 works fine.
But if the Pc cannot read it,I cannot reprogram it again.
Do I need a Cas programmer to fix it now.
Or is there a driver for xp for the matrix reborn cam ?
Any advice would be helpful.
Yes, I'm afraid it's the CAS only in that situation. Maybe you know somebody who could put either MR or MRev back on with a CAS, then you would be OK again with the pcmcia route.
Norm.
