MBC ACTION MBC2 MBC4 and MBC MAX in the uk
Djskutz said:
Where are you in the uk as im
In ireland and just bought a 1.8m dish and would be interested in trying to receive these channels
If you are referring to the member kungu, his profile says he is in Limuru Kenya in Africa
Cheers topper, I'm using tapatalk app on iPhone, so it doesn't tell me at all
If your talking to me im in South Devon and the signal booms in most of the time.
Do you get admc sports in hd and jsc hd, if so, what is your readings
Nothing for me on the new frequency and the original mbc channels are down to 53% this morning from 90% late last night
kungu said:
Good morning,
Try out the new frequency of MBC channels on BADR 6 frequency 12437 V DVB-S/MPEG-4 SR 27500 FEC 3/4
I do after 4 pm with ad sports signal strength between 35 and 44%,jsc is weaker for me but in clear conditions I've seen 35% signal strength
So I wouldn't think I'd get it then considering I'm in the midlands in ireland
If your referring to the adsports package Djskutz its hard to tell really but i do know that an official sub is paired with a receiver which i believe has a sub standard tuner inside,for reliable reception i think your looking at a 2.4m dish.One thing i did notice while watching adports 8 HD fta it seems to lock on and is watchable at what i would consider to be a low signal strength for HD at 36%
Must be a very strong transponder so, ah sure no harm in trying
Dj skutz u will recieve a lot of channels from 7 west atlantic bird 7 with your new dish as the beam is better than nilesat 101 and 102 and much better than the near impossible nilesat 201 u will get all the mbcs, fox movies, fox ,play movies ,top movies and many more ive heard ad sports hd is receivable on 26 east badr 6 on a 1.8 but the signal is not reliable this far north but mbc is easily recieved on badr 4.
Not bad , Offaly and Dublin are on camparison for south or am I more southern, what part of Dublin are you in driver
Djskutz, where'd you get the dish and what'd cost ya?
I get MBC ACTION MBC2 MBC4 and MBC MAX, 26e on a im gibertini with cm feedhorn, inverto lnb @ 86%, thats in the midlands of ireland.
Its very strange as my mbc frequency has got weaker but my adsports is stonger than normal today
I had that problem on 26e with my last lnb, which was an invacom one, changed it then it was ok.
Human I got the dish in satellitetv.ie and cost me the guts of a grand, ordered it before Xmas and got it Monday
Dj skutz i am in santry mbc usually comes in at 69% on my tm 6900 but its down to 55 today i think it is been jammed like some others on badr over the last few months
I can't even get the AD Sports transponder, don't think I ever have been able to. MBC transponder is 54% quality but it is overcast and raining on and off too.
I get 86% on mbc's, but with it been overcast and a bit misty its at 81%.
