metabox
P
pejvak
hi
I am a problem with my eMetabox digital receiver,
when i was programing it with new software it hanged up and don't work now , please help me.
M
mmsaidat
if it only displays ON on the front display screen try this :
. 1. Unplug Metabox and remove the cover.
2. You'll find 2 PCB, power supply and the main board.
3. Remove the cable from the Power supply to the main board.
4. From the pins on the main board (usually marked) short the
marked
supply line to ground. Do the same to the Power Supply board.
Note: The whole idea is to discharge all the capacitors to
reset
whatever data/info on the RAM to, at least, restart the system
for downloading.
5. Return back the cable from the Power Supply to the main board.
6. Connect the PC and plug the metabox and turn on the main power.
Do not push the front power button
7. Run the software and hopefully downloading will be a breeze.
els your STB flash was damaged
if it works but there is no signal then you have downloaded the wrong software
Adnan265340000
i try all trick but still display is one
so what can i do
R
ramith
tell me the site u down loded software. Reply to my mail with your receiver type (emetabox-01 -silver colour one or emetabox-02 -black colour receiver) i'll send u the
files.
ramith@dialogsl.net
S
salami
I'm searching for metabox(receiver)software.
thanks for help.
amandegar
Hi every one have a same problem:
after approximatly one month with help my friends i could solved that problem.
In first step you should make JTAG cable. you can find software and schematic map in below address.
http://www.megaone.com/emetabox/software.htm
software name is jkey...
after that you must program your receiver with JKEY and flash rom dump file...
OK..again you can find that in this address
http://groups.yahoo.com/group/emetabox
Go to the files link and download file you need.
after that try , your receiver should go from ON to Strt when power on that.
ok....now you should update that software and channels with RS232 Cable.
you can find update software and programmer in this address
what do your receiver?
my receiver is a good boy...after that procedure do good work...work better befor ;)
suggest: i want buy a small and powerfull fan because the heat sink of microcontroller so hot when i`m show the channel.
i think after that my receiver hang up decrease...
abstract:
1- Download JTAG software and make JTAG cable
2- Dwonload Flash rom Dump file
3- Program your receiver with JKEY software and flash file
4- Download Upgrade file and Sender software
5- Update your receiver with Sender software and Upgrade file also with RS232 Cable
-- if you want but a small and powerful fan.
Metabox1 Black Box have a STi5518 MicroController..that`s a so powerful chip with extreme ability...that chip manufacture has ST Microcontroller
if you want see ability and features you can download Datasheet from this address
http://www.electronics-lab.com/forum/attachments/STi5518.pdf
have nice day and night with Digital Tehnology ;)
G
gsmsikar
@amendeger
there are many receivers with this sti5518 chip , can we have all these functions in all those receivers?
help
S
shred
amandegar, which JTAG cable and where to interconnect them.
T
TIANA
Hi
When i finished to downloads JTAG files the software do not work, so can you send the right files to my adress mail :tianaravoni@yahoo.fr because i heve the same problem
abstract:
