Minimum size dish for Monoblock
Likes
Comag SL65/12 Camping Set with added Monoblock Universal LNB
Birmingham England
#1
I have a Comag SL65/12 camping kit and have fitted a monoblock to it so i can view both Astra 19 and Hotbird 13. Trouble is i can't quite manage to get both at the same time at one dish position.
The dish is a circular 35cm type. Has anyone managed to set up a monoblock on this size dish? and if not, what's the minimum size i need to view both satellites from a Monoblock at one dish position.
Any advice greatly received.
Topper
Amo Amas Amant Admin
Likes
3,273
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Use a bigger dish is my advice, 35cm dish is too small to get both with a monobloc. As regards which dish size will be required I could only guess to be honest and my guess would be 60-70cm
Likes
Birmingham England
#3
Cheers Topper, i've spent all day trying different combinations but i reckon you're right the dish just aint big enough. Have to trawl through Maplins website and see if i can pick something up there.
Hope i can get away with a 43cm high 60cm wide elliptical one.
Likes
1,279
#4
Look for something like a Raven Gemini 70cm, should do the job well.
Likes
Birmingham England
#5
Thanks rolfw, problem is i live in a flat and the dish will be on my balcony so discretion is a must.
Unfortunately in this case size does matter ;) Lol
Likes
1,279
#6
OK, then you could try a 60cm transparent dish, should work OK with the monobloc LNB.
Likes
Birmingham England
#7
Thanks rolfw, maplins do a 60cm Eliptical Mesh Dish :)
Likes
Birmingham England
#8
Well i've done it guys, i bought a 65cm elliptical dish and it works fine with the monoblock. I now get both Astra 19 and Hotbird 13 without moving dish, only thing is i had to compromise on the signal quality to get about 55% on Astra and 60% on Hotbird, but it's good enough for now.
Thanks for all your advice people.
Topper
Likes
3,273
#9
Glad you got sorted :) and your landlord will probably not be any the wiser
Likes
Birmingham England
#10
Lol Topper, my mom's got a spare bedroom ;)
