GJ89
- Az-Box Premium HD+
110cm Triax
DiSEqC 1.2 motor
- Heerenveen, Netherlands
Hi guys,
I have a problem receiving Moldova International.
-http://www.lyngsat-address.com/tt/TV-Moldova-Int.html
I've gone back in time on for instance KingOfSat as well and have picked up these frequencies:
12620MHZ 3365 3/4 V
12704MHZ 2748 3/4 H
12703MHZ 2748 3/4 H
12621MHZ 3362 3/4 V
12621MHZ 3364 3/4 V
12739MHZ 3364 3/4 V
Now, the one which is said to be active is 12621MHZ 3364 3/4 V, but even though I find channels, working properly, on the same transponder (RTK-Sat) it just won't pick anything up. I am 100% sure I'm on the correct elevation and azimuth, and noticing I have a motorised system I never need to adjust the LNB.
I have no idea what the problem could be. Is it possible Moldova International has switched to another frequency? Or am I the problem?
12620MHZ 3365 3/4 V
12704MHZ 2748 3/4 H
12703MHZ 2748 3/4 H
12621MHZ 3362 3/4 V
12621MHZ 3364 3/4 V
12739MHZ 3364 3/4 V
Seems I'm not the only one with the problem. Could this new launch have anything to do with the fact Moldova International seems out?
