Mono block lnb on a sky dish.
mbrandish
Sky+ hd, Packard Bell desktop,toshiba laptop and built in freeview on tv and old nockia stb.
gtr manchester
Hi is it possible to fit a mono block lnb opn a sky dish or even a single lnb so i get either 13.east or 19. east and get good reception. thanks in advance.
Zone 2 dish, yes - in principle.
But your intentions are not entirely clear ............
ie If you are using the Sky dish for 28E and intend to carry on doing so, then a Monoblock would only be of value for getting 23.5E with a standard 6 degree device (I know the Satellite separation is less, but it does work). To get 13E or 19E would require a multi-LNB bracket and possible realignment away from 28E (but using an offset LNB to carry on receiving it).
If you are proposing to realign the dish - or have a spare dish - then a 6 degree Monoblock on a Zone 2 dish will work for 13E and 19E.
There have been a couple of Threads in the past few months about using a Zone 2 Sky Dish for offset reception, so have a gander around the archives.
PS: You can get Monoblocks with fixed spacing other than 6 degrees (eg 3, or 4.5 degrees) and you can get one adjustable up to 12 degrees.
Hi thanks i want carry on receiving sky my sky dish is attached by a bracket on a pole i could put another bracket on the pole and put another dish for the mono block.Could i not put a single lnb next to the sky lnb and receive hotbird.
