monoblock and other dish question
settopbox
Dm 500s, and 800hd
humax 5400, antique
dell 1530 vista,
dsl internet
southern ireland
I have a quad LNB WITH MY S K Y DISH, WITH 2 OUTPUTS CONNECTED TO MY REGULAR S K Y + BOX AND WITH ANOTHER WIRE COMING IN TO MY HOUSE BUT JUST LYING IDLE.
I ALSO HAVE a monoblock LNB with switch built in connected to my dreambox on another dish
what do I need to connect up the idle s k y wire to my Dreambox so as to have the monoblock and the 28.2e s k y wire all coming into my dreambox.
Many Thanks.
Well, you can't use a standard Monoblock in cascade with another DiSEqC switch, so perhaps your simplest and cheapest option is to use an A/B Isolation Switch.
Connect one input to the Monoblock and the other to the 28E feed.
Then you can select, at the push of a button on the switch, the 13/19E arrangement you already have or just the 28E feed.
There is a way but you would have to ditch the monoblock and replace with 2 single lnbs a feed from each lnb and the third from the sky lnb go into a diseqc 4 way switch and then you configure your dreambor diseqx opt A/B/C/D
You always lose signal quality with monoblock lnb's they are the worst invention ever as you cant skew
It should not be too expensive as lnbs cheap at 6 pounds and the dual lnb holders are as cheap as 12 pounds
Thanks for the Help.
will have a think about it.
A monobloc can be used with a DiSEqC switch - BUT the switch needs to be of the rare (and expensive -around 60 Euro) "option" type (such as the Spaun SUR211) rather than the common "position" type. See here
_http://www.spaun.de/?lang=en&modul=products&product=871437
Yes, uncommitted switch.
_www.televes.com/hojastecnicas/103169.pdf
