motor advice
For ease of installation and set up i'd recommend technomate 2300 or motech disecq motors, but if your dish is high or in an exposed position it maybe worth going down the 36v route as they are a lot stronger and faster, hope this helps:)
Steel or Aluminium version?
Shouldn't be to heavy for a motor as suggested above (TM2200/2300), they'll take heavier. Sounds as if you'll have a nice set up when finished :)
thanks im using the humax hd2000 with it please tell me do any motors out there have a degrees guide on top to help find satellites mines underneath and difficult to see
