Motor Dish house move
sitja
sky digital, dreambox 500s using cccam 2.0.9 with gemini 4.2 image
ireland
Hi guys im moving house soon and will have to set up my motor dish again at new location im just wondering do my due south sat change?? It was 8w, my new place will only be about 15 mins drive from my current place? Also im setting up with dm800 should i try with usals first- once i fit the dish level?
As you're only moving 15 minutes away your due soth satellite should be the same, and if you move the dish to this, using your receiver, then set it up on 8W, at your new place, your receiver shouldn't need altering.
Assuming you are tracking correctly on the new set up of course. . It'll be a fresh install so input your new coordinates, drive to 8W and make alignment.
