g60edition
- TM5400CI+ TM1500CI.Dreambox 500S HD
80CM Motorized dish
90CM Fixed dish,HotBird 13 & 28E
Sly dish for freeview
- Portsmouth,Hampshire
Good morning all.I have just re installed my dish and motor and has been working fine on all selected sats.Yesterday I lost everything the stb moves the dish to the selected sat but will not clear.The lnb and and other output from the motor do seem a little loose and I thinking that some soldered joint have come apart but will drive the motor but when it stops its just not making good contact to recieve a signal.I have tried the stb on a fixed dish (Astra) and I get all the FTA so the stb stilll works.Just to add I can swing the motor via the menu and get a good signal but it wont hold the settings.I know its not a connection problem as I used snap and seal and have tested them.
The motor is a hh90 stab and my stb's im using are TM5400Ci + and a TM 1500ci+
Thanks in advance
Thanks in advance
