Ok here's the situation. I've got a 110cm dish, a dreambox 500s and a Moteck SG2100 motor and i've been trying to get it work properly since about January this year. After about three weeks of trying early January I gave up and decided to just bypass the motor and just use it as a fixed system again. Now i've been attempting to redo the install and I can't manage to get a signal on ANY satellite. I've tried Thor, Astra 1/2, Hotbird, Atlantic Bird, Badrsat and Eutelsat. The only one that managed a semi-decent signal was Atlantic bird which got a lock and was able to display about two channels. Nothing else works.
I've tried every tutorial across the net. I've bought a digital compass and made 100% sure the motor faces 180 degrees south and i've set my elevation to 29 degrees as recommended for Dublin. What's worse is my Dreambox shows 90% signal SNR no matter what occurs. It even shows that with the coax cable unplugged. The AGC is always 63% as well but that managed to go to 91% on atlantic bird.
What's even worse is that I can't even get a single satellite signal again. I'm completely stumped as to what i'm doing wrong.
I even tried one of those sat finders and it apparently got a very good signal, I tried plugging it in to the receiver and nada. Tried about three different LNBs and two other receivers.
