Fano
- T90 Dish and Smart 60cm Dish @28.2E
Receivers:Dm800s,Dm600s,Dm500s,
Ferguson Ariva 120,Opticum x403p,Tm 500.
Satlink 6906 meter
- Ireland
I have encountered a problem with my Diseqc Superjack DG120 motor.
It has worked fine for almost 2 years .
I recently realigned the dish and it was working well.
Now,it has stopped moving Eastwards.
It will move West allright .
I tried moving it manually via the buttons underneath the motor but it makes a clicking sound when I press it to go East.
If I move it East in the dreambox menu it wont move .
I tried making it goto zero ,it worked a few times but now it doesnt seem to do anything when I enter gotozero.
I have tried 3 different receivers ,my 600s,500s and 800s so its not a power issue.
I replaced the cable between the motor and receiver but that made no difference.
Its currently stuck at 30w and the signal is good .
In the manual it says the motor can be reset by inserting a pin into a hole but there is nothing in the hole,its just an open space.
Is it time for a new motor ?
