Motorise Current Dish
kman123
None Yet
Thanks for all the info in this thread guys. its helped me to decide what I want with my new sat setup.
satelliteman said:
The aforementioned auction item posted looks okay although you would want to mount it using a TK arrangement. Those L type brackets are not up to much.
Just a quick question.
Where would I pick up a good tk bracket set to go with that dish? do i need one or two, and would it go easily with the dish? thanks.
Creative Satellite would be my suggestion. Actually, it is my suggestion.
And you need two: A "T" and a "K". Naturally.
satelliteman
Or if you can get a K+K, even better :)
kman123
None Yet
Thanks, I will check them out, and see what I can get my hands on.
