Motorised Satellite Dish Will Not Move
Have you tried a reset?
Can you nudge the dish in DISEqC 1.2?
If no luck, also worth checking cable terminations on the motor.
Could also be a power supply fault too so if you can lend a power supply to try it might help
It couls also be an issue with the receiver software. I condemmed my old TM-2300 motor thinking it had died, when it turned out to be an issue with the Open AAF image on my Gigablue becoming corrupted.
How old is it, and can you reach it without risking life and limb?
