I have scanned the forum, but haven't found answers, so here goes.
I’m a complete newby to Sat TV, but am usually capable with things technology, once I get through the sector-specific jargon. However, I’m struggling a bit with the setup of my dish/system.
Any guidance will be much appreciated, and thanks for reading!
Details are:
Latitude: 52.2467°
Longitude: -2.7058° (West)
Dish 80x90cm (ovalish - steel I think Unbranded)
Motor – Technomate TM-2600 M3 DiSEqC
LNB – 2 port ‘Universal’ from Maplin
Receiver – Technomate TM-5402 HD M3 C1
Cables (all good quality, almost new with great end fittings)
Cheap and cheerful Satfinder (a £fiver from Amazon)
The dish is on a portable stand and yes, I have the vertical pole VERTICAL. I checked the position of the best sat (in the sky, relative to where I was, I think it was IntelSat) and literally pointed the dish to an imagined dot above the southernish horizon just to check the system fired up. Imagine my surprise, when I booted the receiver, I got high quality UK TV (channels pretty similar to all the Freeview ones). This receiver was not setup in this area (NOWHERE NEAR) and the Lat/Long were literally miles out, so attempts to motor the dish to anything other than my 1st pot-luck satellite failed.
I now want to site the dish more permanently and have the following questions:
Details are:
Latitude: 52.2467°
- Both the dish and the motor have adjustable inclination. I’m guessing the one on the dish is made for a non-motorised setup and should be set to 0°/90° (vertical) and the scale on the motor used for my latitude (eg 30.2° for 0.8W IntelSat). Is that correct?
- If I set the motorised dish to due south (offset for magnetic deviation), the inclination to the recommended angle and set my Lat/Long in the receiver settings, can the receiver not do a blind scan of the horizon to locate the satellites? I know the sat locations are all available in the receiver, so surely it would make sense to have a bit if internal logic to scan about to find a transponder of a known sat, then use that as datum??
- If that isn’t possible, how do I tell the receiver to set the motor to the 0°/0° position, so I can align the dish with due south/correct inclination?
- Is there a guide for everything in the Technomate Receiver menu! The quick setup guide is pants and there are loads of menu options such as Blind Scan and other reference terms, units of measure and axis title that are meaningless (to a newby).
- If I get the receiver to point to a specific satellite (say 0.8W Inelsat) and the menu is expecting that, then point the dish and adjust it with a satfinder to get a great signal, does the box know if I home-in on the wrong satellite? That might sound dumb, but I see the satellite name on the TV once selected, whether or not the dish is connected, so that reading is coming from the menu, not the satellite….
- Does the receiver understand/confirm which satellite is talking to it, even if I have selected the wrong one on the menu/in the sky?? There really are a lot of them up there, they are only a tiny angle away from each other and even micro adjustments mean miles of error up over the horizon!
