- May 26, 2020
- Raven mk2 zone 2 x4, Channel Master: 90cm x3, 1.2m x2, 1.8m PF. CM polar mount x2, Az/El x3.
- South Durham
If I mount an offset Channel Master 1.2m horizontally/at 90 degrees on a polar mount, along with adjusting the declination do I need to rotate the polar mount on the pole, or leave the polar mount where it is and make a bracket put the dish into the correct position?
Both would change the azimuth of the dish face at an amount equal to the offset angle but I can't get my head around if there is any difference between the two options, if one is the correct method or if I've got it completely wrong
