OldBen
Mad Scientist
- Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch.
- UK
Hi All,
So I currently have a Motech motor on my 80cm dish, not unlike the one in the howto PDF ;) but once again its slightly out of alignment and I have noticed that the last two years have not been kind to the finest far east finish on the bracket (now racing red) so it needs some TLC.
I used to use the dish mainly with a Technomate receiver, specifically was watching Czechlink on 1West, but lately I have been playing around more and more with DVB-S2 (i.e. BBC HD) on 28.2 on the PC in the lounge that runs MythTV - partly for BBC HD and partly as Czechlink card expired ;)
I am thinking that I might connect the dish full time to the PC, but the motor is not supported (well moving it anyway, it being there has no effect apart from some signal loss maybe) technically, although I can get it to work with utilities, I can't get it to integrate well with application I am using.
Rather than leave the Dish on 28.2 for BBC HD, I was thinking about taking down motor (bracket needs some love if it stays up there) and just fixing dish and getting some offset LNB's and a switch, had some questions for the combined collective:
1. Can I get an offset bracket that will do 28.2E, 1W and some other useful sat? (13E maybe?)
2. 1W comes in strong at the moment, but with offset will I be loosing much signal, I understand the reflective physics etc but it occurs to me some signal loss must occur when not having a single central collector?
3. Can I use dual or Quad LNB on an offset bracket? (thinking next TV might have freesat built in, wanted 2x LNB on 28.2, third output to use with Technomate as well could be useful).
4. Anyone recommend a 2 or 4 way Diseqc switch? (will be checking site sponsors shortly)
5. Anything else I should think about?
I am braced for the flood of "keep the motor" replies, but as I can't steer it effectively it seems a switch and offset arrangement would give me the most options with my PC setup. I know the satellites way to do it would be keep the disk on the technomate and put up another small dish for 28.2, which I have considered, but I think its overkill, and main dish bracket has to be sorted in any case.
Any pointers appreciated as always! :-worship
