MR Not running or scrambled
Z
zibi
Likes
Technomate 5500 Dapci,
TM-5000 Remote control.
Pach to next 7500
90 cm,Motorized dish, SG2100 Motor
Nokia Analogue Receiver
Sky box
Bucks UK
#1
Does anybody have the same problem than me? My receiver freeze every 10 to 20 min and this message appear on the screen "Not running or scrambled". I have to turn off my receiver and turn it back on. This happend when i watch TPS but not only.
I am using a Technomate 5500DAPCI with MR1.23 but it was also happening with MR1.18.
Any thought?
R
rkhsaw
Likes
Humax, dragon, Matrix, 4 dishes
France
#2
Hi
No, you are not the only one.
I'm not an expert but it seems that some cams/cards/receivers are more stable than others.
i would suggest you start by checking the signal strength/quality of you signal in your receiver setup menu first. -you can't expect the software to be rock steady if there are data errors in the signal. Aim for 75% or better.
try different firmware/software versions for your cam/card or whatever you use. some may be more compatible with your receiver than others.
Lastly, it's amazing these systems work at all ! Don't be to hard on the guys that developed and distributed the various "techniques". A few drop-outs is better than a blank screen !
R
R
rkhsaw
Likes
France
#3
just an update for anyone interested; I now have a dragon and it has far less re-sets than the Mr I used to use. just about all channels are rock-steady and it only gets confused when i zap too fast.
so far, I'm very pleased with the dragon.
humax 5400, dragon, pred 3.30
R
L
lilitheking
Likes
Any thought?
Try mrb300 for MR or MRV : it works better without any freezes!
Regards
B
bigkenny
Likes
North Wales
VU+ Duo and Dreambox DM 518-S also a Technomate TM-6800HD using 1 metre dish with motor
North Wales
#5
Any thought?
yes same with me I use a Strong 4355 with MR CAM
