hy my friend
thanks for your special help
i wanna kn ow from u some things about this good dish!
i made some test with my 3,7 with the new lnb from
INFOSAT
the one with C/ KU BAND inside in one
i can see that works very well in C BAND
but in the ku band
works no good
in fact i have some problem to receive the yamal ku band
that in my zone
is well received with a 2,00 m dish
so
i have an idea
or is the F/D that is no good
in fact the F/D of the dish is 0,37
the maximum F/D of the lnb is 0,5 or 0,7
input reflector type c band ku band
prime focus off set
you mean that this kind of lnb is no good
for the prime focus 3,7 prodelin????
or there is some other problems?????
if i order the kit for ku band illuminator
from them ( prodelin )
i have my dish with c band illuminator
u mean that i can install without any modify????
or i must modify the feed support bracket ( 4 )!!!!
thanks if u wanna help me
you have some european prodelin distibutor address????
or i must order the kit from the in the USA????
CIAO
2
INFOSAT
but in the ku band
works no good
that in my zone
so
i have an idea
prime focus off set
CIAO
