Multi 4 LNB Diseqc switches
Oz_P_Nut
Visit site
pj::
There are 2 new Dishes coming onto the market (T55, T90), they are capable of having 10 & 16 LNB on 1 dish, yes you read right, 10/16 LNB :)
Question:
How would you connect multiple Diseqc switches to use all
16 LNB?
thx
Oz
Hello Oz,
From memory I believe that 8 is the most you can get from a single switch, so you could then insert a 2 way manual switch for the two banks.
If you look at some of the earlier posts there is quite a bit of information on the torroidal dishes, not least the fact that they are not quite as efficient over the whole arc covered. There is also a problem due to physical limitations in spacing of the LNBs.
Rolf
2old4this
Honorary Admin
Cloud Cuckoo Land
Oct-Nov/01 edition (just out) of Tele-Satellite international includes a write-up on the 90cm toroidal dish, which was tested with a bunch of the new Alps mini-LNBs. Very positive test. Beautiful bit of kit.
2old
