Multi Emu or MR1.13
Gladiator8387
CypRuS
I have cas interface programmer.. and a mm..
I had MR1.13 on my module.. but wheen cyfra+ opened.. i erased it and wrote MultiEmu 042 on the cam so that i can get cyfra+...
But the problem now is that i can only get cyfra+ :pp
Is there a solution here.. to have cyfra+ together with the other packages on a single .bin file?
Not that m8,
Using the emulator here too on one of my MR cams and the rest on my M Revolution cam.
Or use an Titanium car with the file for Cyfra+
CHeers.
Cor.
hello to all!!!tryed installing multi emu 40 on matrix reload with mr1.13 but i get a error """CABLE REMOVED OR BAUDRATE TO HIGH FOR THIS STB""".anyone can help??thanx
There is an file out for Cyfra for the titanium
The multiemu can only be put on the MM/MR cams with the cas1 or cas2 interface, and reverting to an MR software can then also be done by cas interface, NO fun card method will put it on the cam.
Cheers,
Cor.
Cheers,
Cor.
I have cas interface 1.... can't i have mr1.13 together with the multi emu 042..so that i can watch whatever mr1.13 gets together with cyfra+
You cannot have both loaded on the CAM at the same time, why not use 1.13 and a Titanium.
Hi Rolf
Please advise - Which file to be programmed in Titanium?
Thanks.
At the moment Cyfra uses another nano, so not possible to watch anymore at this time.
Must say it didn't take much time for them to take steps to get the screens on black again.
So, not possible now to watch i'm affraid.
Cheers,
Cor
thanx cor for the xsplenation!!!unfortunaly the 2 tita card that i got are having the NO ATR problem so wondering if you may got a solution for that!tried lots of software like RESURECTION BETA and 2 other with no luck!hope u can help!thanx
