Hi, I have just moved into a new block of Apartments (12 in all) That share one 3 LNB Satellite Dish. The 3 LNB dish feeds into a small room that has multiple splitters and amplifiers and so (At least thats what they look like) There are also finally a 3 input/ 1 output splitter that feeds into each apartment separately 1 coaxial cable. I have (at the connection in my apartment) Split the cable with another 4 way splitter feeding to 4 location in my apartment. At the moment i only have 2 boxes hooked up and i have noticed that if one box is in use.. the other box has a very low signal and most channels and vice versa.
I have seen that many people have recommended an in-line booster but i am not sure how and where to connect it. Some have IN & OUT Connection, Some have to Power & To Antenna (That is easy to figure out) also i could not find the best location to install this if it has to be one for each receiver before the splitter in my apartment.. or one before the splitter..
Any help is much appreciated... if i did not make myself clear in any way and you need more info please let me know.. Thanks
