multi strand cable
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Hi guys
I need to route two cables from my LNB to my livingroom, I need one for the Digibox and one for the Qbox. Rather than have two cables side by side, is there a single cable with two cores?
Thanks, TG
T_G said:
Hi guys
Thanks, TG
Even if there is such a cable, I wouldn't use it because they wouldn't have the same quality as the single ones.
Quality is not an issue, is only for a fixed dish for 28 east
It would be a non standard cable type, which means you might need to buy a minimum length (drum, spool, etc.)
Check in your local sat shop (if there is one) and see if they have such a cable in stock.
They would probably ask you to make a special order.
I could be wrong off course, but I try not to buy non standard parts.
By the way, whay would it affect quality?? If each one would have the same shielding it should not make a difference? I just think it would look much nicer having one thicker round cable than a few running alongside. Especially when they are visible from the outside.
I would expect Sky to use such a cable for their twin tuners receivers.
If they don't, then there must be a good reason for that.
Here is one from Maplin
_http://www.maplin.co.uk/Module.aspx?ModuleNo=219139&TabID=1&C=SO&U=strat15
The outer diameter of each one looks smaller than usual, which would affect quality.
Is black OK or do you need a different colour?
Thanks HB, very useful information. Will try to locate something in Germany - I think it will look much neater than having two cables.
That coax is configured side by side and is only RG59 not RG6 type so has a large loss. Its ok to use for short distances but to be honest you wud be best off using two runs of rg6 CT100 WF100 etc as the loss is loads less. To secure the cable use flat clips like used for electricial cable clipped every 9 to 12 inches and it will look fine.
try to see if there is a german version of the twin wf100 cable as that will be enough for what you want
also over in germany is it only white or black cable that you can buy ? the uk has brown as well which matches better to the bricks used in houses
You can buy cable clips sepcifically for two wf100 or RG6 side by side.
Yeah we call that twin RG59 stuff 'shotgun cable', I've seen it in black and white. Sky installers seem to love it but I wouldn't use it myself.
Bit overkill but for future reference you can get Multi core CT100/RG6/WF100 with 4 or 5 lengths + earth in a single outer sheath.
_http://www.net-comber.com/cable-loss.html
Add the lengths required into the appropriate spaces and click.
There is some additional loss in voltage between the LNB and the receiver when using the RG59 type, owing to a slight increse in coaxial impedance, but it is negligible unless you are talking really long distances.
How long is the cable run TEEGEE?
I use the Sky WF65 on quite a few jobs, it is compact and the customers like it, works perfectly well for moderate cable runs and will fit through an existing 10mm hole.
I guess it is no more than 10 - 15 metres, not very long. It is just for the permanent dish pointing to 2D, so no motor. It is simply so I can connect the Digibox and the second tuner of the qbox to it
You can connect whatever you want to it, it isn't round, it is shotgun, so two cables side by side, only in white or black as mentioned earlier, or there is the WF100 shotgun, in Brown or Black.
What you can of course do, is run two lengths of WF100 or similar and use the twin cable clips, would have a similar effect.
at that distance the shotgun type cable will work fine, that's if you can get hold of it in germany.
Here is a twin coaxial cable from hm-sat.de
_http://www.hm-sat-shop.de/montage-zubehoer-koaxialkabel/twin-koaxkabel.html
Doesn't look that good, especially as a 4mm diameter.
Here is something better, with 2x6.8 mm diameter
_http://www.hmm-tv.de/K640--Twin-Koaxkabel-KH9-%3E80dB-100m-Ring.htm?hmm=f050c5341159a8d42efcd80bf6e3fa8c
Cheaper spool
_http://www.ac-sat-corner.de/shop/product_info.php?products_id=2266
But minimum order is 100m
Use Google for more results with keywords:
Twin-Koaxkabel or Twin Koaxkabel
As Rolfw and wod have stated wf65 will be ok and prob ideal for you-i find it good up to around 20 metres and will fit through a standard 10mm hole, the biggest downside i find is the f connectors are only twist on and always seem to start twisting the outer sheath of cable no matter how carefully the braid is stripped.
I personnally use wf 100 whenever possible for twin cable runs-yes it is expensive,a larger hole needed 14mm, and bends can be difficult to run neatly. but low loss and can use compression/crimp connections.:)
There are both crimp and compression connectors available, I use the crimp connectors which are available from Alltrade, plus I have asked them to get the new Cablecon compression connectors in, work really well.:)
