Multidec 8.2 problems
M
MansellMindy
I have finally sorted my LNB and can receive many channels except the pay channels using my Skystar 1.
I tried running Multidec 8.2 and first got IRQ sharing problems with IRQ 11. This I have resolved.
Now I have a new problem.....Multidec still fails to start but the message in the advert box is in German. It goes something like this....
SAA7146
Boot-sequence
Boot_up.axf
not found
DVB fail
no suitable hardware
Also the error box says : could not set PIDs
Any thoughts as I have tried everything I can think of
Cheers
M
MansellMindy
Sorted this issue also.....
Continues..
I start Multidec and it works fine but I keep seeing a Dish in the top right corner with a cross in it. Its also all German.
If I start the DVB software that came with the Skystar 1 card I then get a signal but things hang up.
A: Is there a step by step setting up instruction guide in English for Multidec 8.2.
B: Is my problem something else....Any idea's
Cheers
You should be able to download a version of Multidec at happysat, there are also instructions in English HERE http://members.home.nl/happysat/MD/DVB_Hacking_Using_Multidec_80.html
Rolf
M
MansellMindy
Rolf,
I already read the information on this link. This is where I got started.
There is nothing that relates to my problem......
I have since installed ProgDVB and this worked straight away.
I would still like to get Multidec running properly though.
Quick question ...I get Ultra Blue TV in my channel list but have been told I cannot receive this through my Astra setup. Is this correct ? Can I use a softkey to decrypt.
Cheers
C
charlie46
Hello
Someone told me how to fix this problem and I found another way.
The way I found :- Go into your windows\system\vmm32 folder, click on mdsaa.vxd right click scroll down to properties,uncheck the read-only box, go and try starting MD again.
The way someone told me was there was a problem with the mdsaa.vxd file size and you have to have the correct one, if the first way dosnt work give me a shout and I will go through the this one.
Cheers
Charlie
