Steve_W
- 60cm on Astra 2 with TM 7100 HD, Triax 80cm dish motorised with Icecrypt S3700CHD looped into TM 5302HD, WDTV Live, Xbox360
- Thanet, Kent, UK
I have a customer who has just moved into a new build.
It was prewired like a standard IRS as follows to lounge plus 8 points:
UHF aerial/DAB aerial/FM aerial triplexed into a single cable fed direct to multiswitch terrestrial input
60cm dish with quattro LNB fed to multiswitch
Single 0.63 sky plus standard shotgun cable fed to each socket (8 in total plus lounge)
My customer has requested that this be changed to allow the above, but to add an option of return path to feed magic eyes from the main sky plus point in the lounge.
Is there a product that combines a standard IRS multiswitch with a return path? I am familiar with the Global loftbox system which I have installed many times and is normally adequate, but my customer wants the flexibility of a sky plus feed plus the return path from the RF2 of the sky box in the front room going to all sockets, but without additional cabling. I think there is a 3rd cable from the lounge to the loft, but if not I can work out a way of adding a cable.
Only thing I can think of is adding an 8 way TV link distribution amp then either diplexing the outputs of the loftbox to the outputs of the multiswitch to the other sockets (all but the lounge), or return from the lounge into an 8 way global amp then using one cable to each socket for sky and one for the return. I suppose I could stack/destack where necessary using this method.
Any ideas??
Thanks all...
Any ideas??
Thanks all...
