Need help about receiver software
Likes
AXIL AD 600 / 605
Visionic Slim 3 (FTA)
FRANCE
#1
I need your help about what type of clone is my receiver ?
You could see down an extract do with Hyperterminal :
DebugPort initialised to 115200, 8, N, 1
fp164.c 990> Success in creating FPI Key monitor Task
Inverted Video..
SIGNATURE=> H/W Major[20] H/W Minor[4]
SIGNATURE=> S/W Major[3] S/W Minor[10]
SIGNATURE=> Manufacturer ID[0xA5]
SIGNATURE=> LoaderText[GMI]
Target Flash MCode = 0x0020
Target Flash DCode = 0x2249
Microcontroller Cut id [43]
Clock Speed [0]
IMAGE_CRC_SUCCESS --> Calc[19C45F68] Exp[19C45F68] ImageSize[ 1179584 ]
Preparing to sSTAVMEM_Init()=Ok
STAVMEM_CreatePartition()=Ok
STEVT_Init()=Ok
STPWM_Init()=Ok
STI2C_Init(back)=Ok
STI2C_Init(front)=Ok
src\pti\ptiinit.c 389> PTI interrupt level 6
src\pti\ptiinit.c 405> Suceesfully enabled the PTI interrupt
PTI_Init()=Ok
STCLKRV_Init(CLKRV2)=Ok
STCLKRV_Open(CLKRV2)=Ok
STAUD_Init(AUD0)=Ok
STDENC_Init(DENC0, InvOut 1)=Ok
STVTG_Init(VTG0)=Ok
STVID_Init(VID0)=Ok
STE2P_Init(EEPROM) Size[8192]=Ok
flashdrv.c 1920> Flash Driver Init OK
vpwmctrl.c 229> Install PWM interrupt 11 at level 1
|| eGOS Version 3.2.32. 0 ||
|| PLATFORMID 551x Date Dec 16 2004 Time 00:04:28 ||
|| (c) Suresoft Systems Pvt. Ltd., ||
Default Resource Disabled - Enable Options and Recompile for usage
, 21471 Info> Device 'OSD0' initialised
fp164.c 1004> Success in creating FPI Key monitor Task
Summary of SDB:-
Name BlkStart PLStart #Records
Lnb 7FE30018 7FE30028 16
Satelli 7FE30068 7FE30078 6
Carrier 7FE30138 7FE30148 313
Service 7FE32D4C 7FE32D5C 1428
Osl 7FE3DFDC 7FE3DFEC 1428
ndbinit.c 175> Valid eDVBE. No_Init
***************************** MPEG - ModuleInfo *****************************
Platform Id - STi5518
Toolset Used - DCU 1.8.1
Compiled On - May 09 2005 at 16:40:41
MPEG Module Version - Ver 1.3.20 Rev.0
_:-sleep_:-sleep_ eIRRXVer3.1.1.0 May 09 2005 16:41:01 _:-sleep_:-sleep_
######## AFTER MMI CREATE()
API_InitCommand() : macros registrations ok
PWM_InitCommand() : macros registrations ok
SSS_GMI/5518
(c) Suresoft Systems Pvt Ltd.,
Version of May 09 2005 at 16:39:50
Built for Chip STi5518 in board CPU Clock Speed = 60750000
Heap Remaining : Start[C044CFF0] End[C047DBF0] Size[199680]
Heap Remaining In SYSTEM PARTITION: Start[C00BAC04] End[C02BAC04] Size[2097152]
eDEMOD - S - STv0299 v1.1.1.0
Date: Jun 16 2004 Time: 09:37:59
( c ) Suresoft Systems Pvt. Ltd.,
sss0299.c 4278> TUNER (STV0299) Module Initialisation
Creating TUNER module semaphores ...
0/12V Control by CPU PIO[20010000] [02]...
LNB Power Control by CPU PIO[20010000] [40]...
LNB Polarisation Control by CPU PIO[20010000] [10]...
Selecting Tuner ... Type[12] Addr[C0]
nsfilter.c 3863> SECTION FILTER Driver version[HWC_SFILTER_55xx/3.0 Apr 19 2005
19:47:05.]
nsfilter.c 4015> Creating SFILTER MONITOR Process @[9] WS[8192]
nsfilter.c 4095> Succesfully Installed SFILTER module
NDB Ver 1.8.15 built on May 02 2005 18:04:40
NAVDVB Ver 1.2.10
BUILDER Ver 1.2.13
STORAGE Ver 1.2.4
MEMORY Ver 1.2.2
DEBUG Ver 1.0.3
ndbfcm.c 4512> Database successfully initialised
gbltimer.c 407> GblClkTimer Successfully Created
eTTXT - 5.4.8 (67359)
16/03/2005
TELETEXT_InitModule() = OK
watchdog.c 697> Created the WD_Thread @12 Stk[4096]
S owe have :
- A STi 5518 with ref. M29W160EB
- A HYNIX : HY57V641620HG
Pleaz help me to found the software to use......
Thanks a lot
0pal
Likes
AXIL AD 600 / 605
FRANCE
#3
Hi ROLW :)
Nice to see u again.
I know this website but there is not the good information (my receiver is a VISIONIC SLIM 3 whith 5000 Chanels...).
I would like to know how to get from the receiver the firmware...
ThanX
0pal
Likes
turnkey 700mhz athelon .5gb ram,120 gb,drive
j-test j-tag setup
#4
are you trying to extract the firmware to a file ? or just identifying
your ird ?
'boxnut'
Likes
1,279
#5
I think he is looking for unofficial update software boxnut, the STi5518 chip is used in many boxes, the Coship is one of them, but whether the same software patches will work is another matter.
Likes
j-test j-tag setup
#6
i agree,i would also be inclined to think paches would also be version specific.
'boxnut'
