need help with a conax card
gerrit
kaon k270, conax
the netherlands antillians
hey people i was wondering .
i have a kaon k270
with a conax card. what cam can i use for this machine ?
and can i change my box to the dreambox 500 c or s ?
thnx already for your response
greetings gerrit :-worship
Does it have a cam slot? If so you should be able to use most cams in it.
yes and do you have any favor which one is the best
also do you know which other box i can use to change this one ?
the dreambox 500 s or c is also good or not ?
no one can say me if its possible ? to change my box for a dreambox 500 s or c
thnx
That because the question isnt clear.
Can you replace your box with a DB500 - probably (although DB's are not an easy receiver to get to know)
Can you change your box into a 500S - no.
500C are cable TV boxes and any discussion of them are strictly forbidden here.
OK mate can you tell me which box is a easy box to work with ?
and that have also a cam slot and also with ?onax ?
greetings
gerrit
greetings
gerrit
Hello gerrit,
It is not clear to me YET why you can't use your Kaon K270?
Why are you thinking of buying a Dreambox 500S when you already have a receiver with Conax support (according to your post)?
Yes, Gerrit you need to explain what you are trying to achieve.
more options maybe i don,t know just asking . but if any one has a solution then pm me or email me thnx already ;)
HB13DISH said:
Hello gerrit,
with this box we have here also allot ha trouble .
no sigal and that kind of things i just wanna know maybe when i take a other box maybe its better . or dreambox i think is a good box !
I would consider the Technisat
TechniSat DIGIT S2
TechniSat DigiPlus STR 1
They have Conax and Cryptowork support.
From
_http://www.sateuropa.co.uk/overview.asp?catid=1&subcat=1
Dreambox 500S need emulation CAMs and it might take you a while until you get it working with your card.
Hmmm "pm or email" need more info to do this.
TechniSat DIGIT S2
From
thnx men that you help me !
@ tuyo >> don,t jugde people about his cover ! beceas the cover knows you better ! ;) <<
TechniSat DIGIT S2
From
hey men i saw these boxes but they looking nice and specs are also good thnx in advance
Gerrit, I was not being sarcastic, this site according to me does not have a PM system and to send you a mail I need an e-mail address which I can not find in your profile. Saludos, tur kos bon.
From Moderator: PM are only open to new members after a certain post count. And remember NOT to post your email address in the forum, its against the rules.
hey let it be like this i know already the info its ok tuyo thnx
