Need help with alarm/burglar systems
I've just had the off site lockup broken into (third time in five years).
The council are happy to replace the door again, but I am somewhat hacked off with the inability to fit a sunken door stop infront of the up and over door, as I have in the back of the house.
Council has suggested linking a remote sensor to the house alarm (I did not tell them I dont have one, which is unfortunately a requirement of my household insurance !), and so I am asking any member with experience in this field, if there is something on the market that protects a house with front/back door, about seven ground floor windows, and can be used to run a remote (wireless ) sensor about 100m away.
I dont need it to call the police - not that I would want to upset them on their tea break.
Total cost of equipment should be in the £1k region, and something I can fit myself.
If I had my own way it would be boiling oil , bear traps and pirahnas in the moat, but in the PC world I live in I would have to pay out the claim should the burglar sue as the insurance cover stops at deterrents
Thanks in advance.
Yeshi
Norden - Near Edenfield (not Rochdale)
Dm500, TM9100, Samsung V+, 1M Dish. Motect 2100..
37Inch Plasma, Wii, Xbox360.
Behind pin 9 on an atmel
Might be a little cruddy but B&q do wirless alarm systems.. dont quote me though as im not convinced these are any good.
splifi
tech1500 and dreambox500s
uk n/w
you will strugle to get a wireless sensor working 100meter from your house you could fit 2 alarms the ones from b&q there about £120 each and work off sola power and very easy to instal
Thanks, the problem is I would have to know when it went off, and arm /disable it remotely, as plod and the locals would not like one going off without some management.
I am checking on the Yale version next week, will let you know if it does the job.
CROSSBONES
S.Wales
Hope the sods didn't take too much stuff mate;)
Yeshi
B&q do the yale version..
Not so much what's gone (car parts, a reel of mains cable and some PC bits), but the hassle of getting the door repaired, and the toerags now know what is still in there.
Things like this make you support the secondary police force, or a local vigilante system (Neighbourhood watch, with baseball bats).
john_graydon
Dublin....Ireland
There is also Motorola versions I seen in PC world over here. My mate installs hi tech alarms for banks etc, I will ask him if he can suggest something for you.
T_G
The Consumate Dreamer
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
Additionally, a good baby alarm helps you to hear when someone is trying to break in, not sure they will work on such a distance. Is a cheap and reliable defence for a remote garage I read somewhere.
