Luke61
- 80cm Technomate, Philips twin lnb, Telekom HD receiver, fixed on 39E
- Leicester
hi all,
new to the forum and i need some help with hardware
got fed up with the online streams beeing so unreliable so switching to satellite as they don't fall as often as the online streams
the satellite i am after is the hellas sat 2 at 39E
i have checked satlex and dishpointer and according to them these are the numbers
now they say that i will need an 80cm dish but will i get away with a 60cm?
it's just that my landlord might not appreciate an 80cm dish hanging above the front door
i was thinking if i can stick it to the wooden shed in the back garden but as it needs to be aimed over the house the aim line is JUST above the house and don't know how the signal will be plus the wooden panels on the shed don't look too strong and i have no idea how heavy the dish is
i have used the satfinder app on my phone to see how i need to point the dish and horizontal angle is quite small is someone with a 60-80cm dish willing to try and point it to 39E and see if it even works?
ok so here are the questions
do i go for a full dish or a mesh one? should i be worried about strong winds?
will any lnb do?
is it a dyi job to mount it on the house wall or should i pay for a specialist do do it for me?
are there good brands or pairs of dish/lnb that will work good together?
i have attached some pics to how how i was thinking to mount it.
the general direction is about the same with my neighbours.
thank you in advance
any advice will be appreciated as i know nothing about this
Luke
Azimuth angle:
133.36° (True North)
Elevation angle:
19.54°
LNB tilt (Skew):
-26.18°
Offset angle:
20.36°
Distance to satellite:
39606.92 Km
Signal delay:
264.05 ms (Uplink + Downlink)
Declination angle:
-7.29°
Polarmount hour angle:
136.31°
Angle setting on motor:
43.69° East
Satellite:
Hellas Sat 2 (39° E = 321° W)
Elevation angle:
19.54°
LNB tilt (Skew):
-26.18°
Offset angle:
20.36°
39606.92 Km
Signal delay:
Declination angle:
-7.29°
136.31°
43.69° East
Satellite:
will any lnb do?
Luke
