need help
tareq145
starcom
syria
hi
i searched all the net and i understood this:
to unlock channels you have two ways:
a. to enter channels code manually.
b. to use computer and use "loader" program and "key" file
and my questions are:
1- are the previous info correct?
2- where can i get "key" files (i saw the sticky thread but sites don't contain any)
can you please help me?????
1) yes, althogh there is also the route of loading a modified receiver image which ahs the keys embedded into it. (Only available for certain well supported receivers)
2) Try the Big Links page on the main index - its chock full of key sites - you just need to work your way through a few until you find one that works..
is it true that each receiver need it's own kind of files ?
or a file can work on all kinds of receivers?
Sorry ! still can't find it !
do you mean main index = the page "Satellite TV support forum & Digital TV support forum"
I dont use key sites. :D
Anyway this is a self help site - we point you in the right direct to find the information and you go and get it.
If you cant be bothered to work your way through the list and find some sites you like then you do without.
