• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
need immediate help please!!!!dm500 crashed
Likes
dreambox
caribbean
#1
in waz trying to install evocamd to my dreambox and try to upadate it manually and when it finished a black screem just appear and my dreambox would not respond. need help please reply as soon as possible please?
Likes
3.6M Ku Band Orbitron, 3.0M Orbitron C band. 1.2M Ku offset, 1.0M Ku Offset, 90Cm/Moteck Ku, 65Cm Ku Offset, 1.2m Paraclips Hydro C Band Nokia Dbox 9500s, Nokia Dbox2, 2x Dreambox 7020s, Dreambox Dm500s, 2 x Dreambox Dm800 HD, UEC 660, Pace HDi PVR
Downunder
#2
Hi Slimthug
Best thing you could do is , connect your box up to your Pc.
Load up Dreamup and try a reflash with which ever image you are using and start again.
Cheers:
Leee
Likes
Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
47°N/8°E/490m
#3
nullmodem cable is your friend here ;)
Likes
dreambox
caribbean
#4
i got it working by flash erase smd then falshing a new image but m yevocamd is gone and i need help to install evocamd on it becuz i didn't innstall by myslf before.
Likes
Downunder
#5
Hell Mate.
You need to do some serious reading .
If you cant manage to get yourself sorted with installing basic addons such as Emus, then maybe the 500 is not for you.
You should find once you have your box connected to you Network, with internet access, upgrading and adding emus via the online server should be all go..
Hell.. I see all your postings.. Your struggling, but obviously done no research..
laterz..
mhku
Likes
19
TM Nano ~ sg2100
Midlands
#6
Have you read The Guide?
john_graydon
Likes
Dublin....Ireland
#7
If your really stuck until you read the guide, why dont you download an image with a cam installed and then just add in new keys.
Likes
dreambox
caribbean
#8
dont worry i got the cam working it wa not that i couldn't get the cam install it was that the key i was using was wrong but i got the correct and it is working.
thanks for replying anyway
