Need info for Factory Reset
C
charcamil
Likes
Strong SRT 4400
Malta
#1
Need to make a factory reset for my Strong SRT4400 but cannot manage to find this funtion. Can anybody guide me how to do it as I forgot PIN and everything I try, I keeps requesting the PIN.
Thanks.:-rofl2
C
charcamil
Likes
Strong SRT 4400
Malta
#3
Thanks Jeff, but already tried that. Usually, Strong uses the 1111 as factory PIN. On manual it says that if you forget PIN make a factory reset (obviosly you loose everthing) but it don`t mention how to do it.
Bye and thanks the same.
J
Jeff_19341
Hi
Have you tried this?
Click on menu on the remote.
Use up/down keys until you highlight "Installation" click on enter.
Use up/down keys to highlight "Factory Set" click on enter.
Then follow the on screen instructions from there.
C
charcamil
Likes
Strong SRT 4400
Malta
#6
Thanks Jeff for your help. Till now when I click enter on "Installation" it requests the PIN. I will keep on trying and keep you informed if I manage to.
Bye
J
Jeff_19341
Very frustrating for you, have you tried an email to Strong outlining your problem? They might have a solution, as I am sure that you are not the only one who has forgotten their PIN.
I know that it does not help, but I have never changed the factory set PIN on any of my receivers. Too many numbers to try and remember nowadays. Best wishes with your continued search for a solution.
C
charcamil
Likes
Strong SRT 4400
Malta
#8
:( Thanks Jeff for your help. Unfortunatly I have to quit and drop the reciever to my agent maybe he can do something. Tried everything and from Strong support, all I got were PIN numbers which did not work either. Anyway maybe if someday I manage to unlock it, I will give the instructions on this forum.
Bye Charles.
