Need Urgent help for Dreambox 7020 settings ip address
nabat
Technosat9800P Omega Dicp/2CI/ R3c Files. Sats hotbird 13E.Astra19.2E.Arabsat.Nilesat.Amos1.Astra2a . Hispasat
Jordan
I was trying to change my network settings in my
dreambox 7020 via the
" Dreambox ADVANCED SETUP UTILITY" and
during the Telnet session I ‘accidentally’ changed
the network settings in the Advanced section from
dhcp to ‘disabled’ and then closed my session, now
am not able to connect to the Dreambox at all .
When I press and hold the "Down " button and turn
on the Dreambox , the LCD screen displays the word
"STOP" but no ip address ,repeat no ip address is
displayed.
Am really stuck. Can anyone please urgently help me
detailing in a step wise fashion what to do to be
able again get the ip address of my dream box.
PS. Somebody suggested solving this problem using a null modem cable .I do have a null modem cable but do not know what to do with it
Would highly appreciate an expert to gude through out of this mess.
TIA
mhku
TM Nano ~ sg2100
Midlands
A null modem cable is used to flash a new image.
Can you boot the Dreambox normally and change the network setings using the Expert Panel? What image are you using?
amman
amman
Tehnosat 9800P Omega DICP
2CI
jordan
Thks yr prompt response.
Yes I can boot normally and I can change network settings from Expert Setup.
I use Gemini 3.4 image.
Regards
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Then I suggest that You change the IP till a nice figur that You can remember, then press save (green) and You are done.
