jonnymaserati
- Dreambox DM8000 with Nabilo Black Hole, 2.0m motorised dish with DiSEqC controler and twin LNB.
Mac Mini with FireDTV S2 and Elgato EyeTV (currently not in use)
Sky+ HD box and subscription (currently not in use as card is in Dreambox).
- Syria
seems that my dreambox is interferring with data transfer through my local switch... any suggestions as to a fix for this?
i have my dreambox connected to a modem via a 1Mb/s 8 port switch, with four other devices connected to the switch. since connecting up my dreambox to the switch i've been having intermittent problems with the devices connected to the switch becoming unaccessible over the network. the LEDs on the switch continue to flicker indicating active data, but i can't access any of the devices and they appear "offline".
the wifi devices i have connecting direct to the modem continue to work fine. eventually, i discovered that if i disconnect the dreambox from the switch, the other devices then re-appear and work fine. i have to reboot the dreambox to get it all working again properly?
i have assigned the dreambox a manual IP address (192.168.1.155) which is out of the range of assigned IPs from the modem. the subnet mask is 255.255.255.0 and the gateway assigned as the modem IP with 192.168.1.1. the DNS is set as per the modem and IP settings.
any ideas?
any ideas?
