Superhori
- Aug 10, 2006
- Age
- 45
- Communal system
- London, UK
Hi everyone!
I just moved into a new flat and was trying to work out what would be the best way to set my home satellite distribution. Some background of the flat first:
-The apartment has 2 cables running in - 1 cable with Sky satellite with terrestrial TV signals, and the other cable with Hotbird satellite and terrestrial tv signals.
-From the entry point of these 2 cables to the flat, the flat is pre-wired with numerous cable to different sockets around the house for TV and satellite. (please see diagram below - there are 8 separate cables in total)
My plan:
1)- I have Sky HD so was planning to somehow install this in the living room together with the normal terrestrial signals.
2) -I also have an Echostar receiver and would like to be able to watch hotbird in the living room.
3) -I want to connect TV link (for watching same sky channel in a different room) from the Sky HD box and wire the signals via the in-built wires to bedroom 1.
-Finally, if possible, I would also like hotbird signals to go into bedroom 1 (via existing cables) to be able to also watch hotbird in the bedroom.
**I am hoping to be able to do all the above using the pre-existing cables only without having to put any more wires**
I have been thinking long and hard about this and think that at least parts 1,2 and 3 of my plan would be possible with existing wires. I dont know how I can split the signals from sky to the living room though as it is only 1 wire coming in - the apartment DOES say that it has provision for SKY HD or Sky + so theoretically, it must be possible but I dont know how.
Does anyone have any good ideas / suggestions as to how I should wire the distribution system?
Thanks!
Superhori
My plan:
Thanks!
Superhori
