gitbash
- Simple start-up satellite system, building up.
- Farnborough, Hampshire
I've only just joined this forum, having already gleaned much very helpful knowledge from existing threads, so thanks!
I live in Farnborough (down south), and I have a French wife & 3 half-French kids. With the help of this forum I've just entered the world of satellite telly.
My current system (which I bought from Maplins last weekend):
43cm elliptical dish and simple Fortec FS-4000v2 receiver.
I wanted to start simple and build up from there once I knew what I was doing. My target is to have both UK and French digital FTA in several rooms in the house. I understand that I will need 2 separate dishes aligned to different satellites, ASTRA for UK, and Atlantic Bird 3 for French.
So far I have ditched the single LNB for a Quad, and, with the aid of a satellite finder (worth every penny, as you know), managed to get perfect reception for UK channels from Astra 28.2E. Having now got the hang of programming the receiver (I deliberately didn't buy a Freesat one), I am now ready to go to the next stage, which is where I need some advice:
1. I cannot get a signal when aligned with Atlantic Bird 3 @5.0W; The satellite finder has a weak signal, but the signal is not strong enough to convince the receiver. I am not surprised at this result, as I always thought that I would probably need a bigger dish to receive from AB3. If I buy a 90cm dish will this be the answer? Or is there something else I need to do? (I will keep the 43cm dish for ASTRA)
2. I want to be able to watch UK and French on the same telly; What is the most sensible way of mixing the 2 satellite signals? Do I need a separate receiver for ASTRA & AB3, or is there some way of feeding into a single set top box? I had thought about buying a box with 2 x LNB ins, but was advised by the chap in Maplins that the 2 "ins" were necessary for HD, and would not do what I wanted. Bearing in mind that I will have 2 dishes, each with Quad LNBs, I would prefer to buy only 4 receivers (i.e. one for each telly), not 8! (BTW, I know I could probably piggy back from one receiver to each telly, but I want to be able to select different channels in each room).
I did a bit of a search before posting this, but I couldn't find anything quite this specific.
I look forward to your answers and help.
Thanks very much,
Gitbash
Thanks very much,
Gitbash
