newbie needs sky+ help
Likes
sky+
chester
#1
hi all
i have just had sky+ installed and am trying to get it through to another room i have put a cable through from the rf out 2 connection on the back with no sucsess any ideas?
thanks in advance
steve:-bash
Likes
1,279
#2
OK, I presume that you've checked the connections on the cable and that they are well made, you've plugged the lead into the back of the other TV and tried to tune the TV into the Sky+ box, is it a straight cable with nothing inbetween?
The Sky+ box is preset at channel 68 for its ouput, if the Sky+ is switched on, you should be able to tune most TVs to that channel.
Likes
sky+
chester
#3
thanks for your reply mate
yes straight as a die
i have now managed to pickup a signal from the sky box but the signal is very week and picture crap
any sugestions?
thanks
steve
Likes
1,279
#4
How long is the cable from the Sky+ box? Do you have the external antenna connected to the Sky+? If you do, then disconnect and see if the picture improves, are the other pictures OK if it is connected?
To change the oputput channel from the digibox, go into the installer menu, Services, System Setup, 0,1,Select and go to RF outputs.
Likes
sky+
chester
#5
thanks again rolfw
have now changed rf output to on and rf channel is set at 68 still the picture is crap any more ideas mate
thanks
steve
Likes
1,279
#6
You don't need to switch the voltage to on, as I presume you are not using a tvlink unit, switch it back off.
Have you removed the TV aerial input and looked to see what the picture is like?
Try changing the RF channel to 21 and retune the TV, if it still gives you a bad picture, try a short lead (you probably have a short lead from your video to TV) and look at the picture on your main TV, if it is good, then you have made the connections badly on the long lead, or if it is pre assembled, it is faulty..
