Newbie seeking help for OPOS programming.
Rock39
Echostar DSB-808 Vi2
80cm Dish Motorised, temporally on a 1mt pole mount, (which tracks the arc if the wind blows the right direction.) Pace 2600 (Sky), Infinity usb+Cas3 programers.
Dell P4-2.4ghz, 512DDR, 75GB HD
Radeon 9800 Graf/Crd. + Ext HD M
Ireland
Hi all,
I've have been programming opos cards using my infinity USB with out any problems by loading flash. Eeprom and Cryptkeys but lately I have only been able to locate .hex files and sets of Microsoft Excel Comma Separated value files such as PMCT, PMCT-Fix and Xamuh_PMCtable**EMU ??? . :-confused
Any one got any advice on what I should be doing with these?
Thanks in advance :)
I thought the PMC table files were for Humax receivers using a specific emulator or people wanting up to date satellite listings with transponder details. but I may be wrong
If I don’t need the Excel Comma Separated value files can you offer any advice on what to do with the single .hex files?
Cheers,
Cheers,
Have never had an Opos and then the only card I have ever programmed is the one shown in my profile and that uses hex files, I would not have thought they were any use for an Opos card. You simply need to find the files you were using previously assuming of course support is still available
