Nikkai A16FB Dish Motor
steptoe
astra 19.2
astra 28.5
hotbird 13
luton
Hi all
just purchased a motor(from a car boot sale looking brand new seals not broken) a Nikkai A16FB maplin electronics
It doesn't seem to want to turn any further than 10 degrees east, West is not a problem
I am using the buttons on the motor and also have plugged it into my promax 4c prolink
same problem West works well but when going East will go no further than 10 East
Can anyone help is it knackered or is there some form of reset i can perform with my meter
or by pressing a reset button
Steptoe
Check its hardware limits if it has them, and reset its software limits. Hardware limits are often adjusted by removing the motor arm and move the mechanical limits.
thanks Robbo
seems to have been a software problem i think.Working ok now
Steptoe
