Nilesat 7W on Td88, 2 questions?
martin-f said:
another one in the 21.6e mux pete,
@ far78 I can maintain I constant lock on both tps but I am using a 1.2 dish, I don't think I would be able to do this with my 1mtr pal,
I suspect, ultimately, that that 20cm makes all the difference plus I am using, by all accounts, a very average dish.
yes far78 when messing with fringe reception every little helps m8, lnb/cable/type of dish receiver etc.
btw have you tried 26.0e for the mbc channels m8 ?
Oh get them fine there! 75% signal quality past few days, rock solid! It's more the lack of AD Sports which frustrates me but, alas, nothing can be done really.
martin-f said:
glad you get mbc @ 26e :-), bigger dish ? :-)
That may be the ultimate solution yes ;)
just bear in mind far78 that the ad sports channels that are easier to reach atm might not be there forever m8 :-), but a bigger dish will always open more horizons :-).
If you can try an Inverto Black Ultra LNB you might get better results. The single comes with a very long neck allowing better focal length adjustments. The twin is not as good and the quad is pretty much standard.
But I have found that only 8 out of 10 singles perform very well and some just don't quite do it.
Good luck
Good luck
I do have a single Inverto Black Ultra, but I am using a twin atm,
I was using an temp very old sky blue lnb berfore I started using the twin, but I will hook the single back up and do some tests :-),
thanks for the info I will report back my findings :-)
I am using a twin now,its certainly outperforming my icecrypts.
I am going to do away with the twin lnb its not needed here, I am wanting 3 motorized 1.8 1.2 1mtr to fill my needs :-).
I went for a twin so that i had a spare link down the mast to connect up my signal meter or other satellite boxes when i'm in the garden if i ever needed it. It made adjusting the lnb focus tonight much easier.
its not needed with a polar mount. well how I set mine up, ive never used anything but a receiver for any of my setups, but I had to use my phone inclometor app for my polar mount lol.
Good luck
Interesting. I've used quite a few twins and singles and they have all worked well and improved the signal from the LNBs they've replaced (with the exception of the old Sharp white LNBs which seem to match the performance of a BU) but I've never bothered to compare the signals between the Black Ultras themselves. I'm about to order another batch so may try comparing them sometime.
sonnetpete said:
There's also Panorama Action and Al-Nahar Movies. English soundtracks with Arabic subtitles. New Style TV is currently showing Snow White & the Huntsman in English but with annoying adverts at the bottom of the screen. I Film English show Middle East movies dubbed into English.
On 11938 you find MBC2 , MBC4 , MBC MAX & MBC ACTION , they are also available on 12322
On 11785 you find DUBAI ONE
On 11296 you find FOX MOVIES
On 10873 you find TOP MOVIES
On 12341 , Panorama Action is there
On 11641 , BAHRAIN 55
On 11680 , MAJESTIC CINEMA
On 12399 , Majestic 2
On 11353 , a new Majestic promo test card
On 11432 , Al-Nahar Movies
On 12226 , FX TV
On 11900 , Kuwait Ch.2
Again on 11296 , FOX ( brodcasting during evening time only )
All these channels broadcast in english . Unfortunately , New style TV And HD chennel had left .
I currently have 734 channels from nilesat 7w (including 8w) with a 1.4m fibo dish i can get MENA and Egypt V(just about) beams but not Middle East or Egypt H beams
I pull in normally over 400, but with this rain i'm on the limit with my dish.
I guess iam very lucky for someone living in the UK, nilesat very handy for football but for how much longer :(
