NO 2nd TV Signal From Sky Box
ddonlon
I have 2 Sky Pace digiboxes, on the second box I cannot get a picture on my other tv when I connect up the cable ( RF out I think).Is it possible it could be disabled I have both boxes in the one room one sends a signal to the 2nd tv one doesn't
Have you set the RF out channel to the same on both?
Go into services, press System setup, then 0,1,select and go to RF outputs, see what it is set to.
ddonlon
When I go into sevices system setup and press 0 nothing happens am I doing some thing wrong
Don't look at the screen, you have to press 0-1-select, one after another.
Razor
Retired Mod
Ireland
That 0, 1 select catches everybody out...at first.
