No More Digi TV ?
Guppie73
motorized 64cm triax dish. Topfield 5000ci, diablocam light v2.3, cas3+
rotterdam, holland
Anybody know what is happening with DigiTV on 1W ?
Since this weekend it is not working anymore.
i updated to Underworld 113 but still no go.
Everything is working ok, except the Digi TV.
I read several forums and tried a lot of things they are suggesting (update the key file, manually update the keyfile, i tried a lot with the configuration, n2au on/off, etc etc) but nothing works.
Does anybody have any idea ?
Mickha
North West
Digi TV 1W, and Polat 13E have knocked out AU on the Diablo, and started changing keys, due to the Euro 2008 championships.
The keys are known, and posted, within 30 minutes and easily installed.
Go into the Diablo Cam menu, using your receivers remote control.
Enter Keys
Enter List Keys Edit
Enter Nagravision 2, second page
Enter the relevant provider, 002111 Digi TV for example.
Enter the key that requires changing: Key 86 = key 00 key 96 = key 01
Select the key and choose Hex or Dec to update, Decimal is quicker
Once you've typed in all the keys exit and the channels will open.
Guppie73
rotterdam, holland
Hi Mickha,
Thanks for explaining.
Now i remember why i dont like soccer ;-).
I am at work and i will try tonight to do as you suggest.
Do you know if the autoupdate will be restored after the euro2008 ?
regards
Mickha
North West
It might be restored in the next release, Underworld 114, but the keys are known early and it is quick and easy to imput them.
Guppie73
rotterdam, holland
Hi Mickha,
I did as u told me and all is well now.
Everything is back in working order.
Thank you very much.
aba
chaparral montery 40 fully loaded
ehcostar ad3600ipvia
3 dishes zone 2 / 1 mt motorized / 2.3 m motorized
nottingham
seems they are now changeing keys 2 times a day
john_m
Echostar 3600, Sky Digibox, NTL
Reminds me of the good old days of d2mac where the canal+ channels at 1deg west would change codes sometimes 3 times a day
