Knotweed
Triumph Rider
- Jan 14, 2006
- Age
- 72
- 105cm Zehnden Dish with 2 x std. quad lmb's Sat 1 on Astra 2 (28.2E) and Sat 2 on Astra 2 (19.2E) running through a multiswitch feeding 4 TV's
- Germany
Hi Rolf,
I think I have located the problem, I think the Vertical High connection on the LNB is faulty. I have done a complete process of elimination with the coax cables (swapping and changing) to check that all the cables and connections are OK. I can get all the BBC and ITV channels without the Vertical High coax connected. I have swithched the 22Khz on. Still cannot get Channel 4 or 5 (now says no satelite signal) with all four coax connected, in the Digibox settings the signal test shows nothing on both signal and quality. I will swap the LNB's this weekend and see if that fixes the problem. I will post the results when I have finished. If it doesn't work I will post everything that I did.
Cheers, Kevin
Cheers, Kevin
