Hi guys,
I will start this off with an apology for my lack of general knowlege...
I had Sky installed for the very 1st time in September whilst living in a block of flats with a communal dish.
Not had an hours bother with it at all... until... I moved into a house.
It is still a communal dish owned by "duh management" and it has lots of wires attached to it - a big bunch in fact. (whether they are 1 per house of more, I really can't confirm)
when I hit record it showed as recording (as per the red light), but at the end of the programme it said "Clashed" and the record didn't work.
I was purely watching a channel whilst recording another, not trying to do too much.
The main problem is that when it is recording - other channels state "No Satellite Signal is Being Received". O-no
there are 2 wall sockets for sky - both of which are plugged in. Did a system healthcheck and there are 2 signals being received although took a while (30 seconds) for the 2nd signal to show.
I thought "fair enough - not set up for sky+"... until last night when I was recording a programme and flicked over to another channel and after a few seconds the "No Satellite Signal is Being Received" message disappeared and it was working as it should!
Is this a common thing? where in certain areas the 2nd signal is intermittent or takes a while to get the 2nd signal through?
Once again sorry for my lack of technical expertise/knowlege but I really appreciate your time to read this and I hope someone can help me as we have an engineer booked and if it's not a problem with the box, they'll charge me £65 and I want to know if I should be cancelling him or not...
Thanks again
Thanks again
