nokia 9600s and SCSI
Fatgit
Patched Technomate 7655
nokia 9600
Manhattan Starlight MX
Matrix Reloaded Cam
Moteck SG-2100 H-H Motor
Barry
Hi can anyone tell me how i can use the SCSI interface on the 9600s.
I have read that you can plug a HDD or a CD drive to it but i cannot find any info as to how they are connected or powered.
If it is possible to connect a HDD can films progs Ect be recorded direct to the disk, if so how.
I have never heard of anyone doing this, thought that it was simply for software upload.
The SCSI is a different connector to the RS232 item.
I know that other receivers designed about the same time had to have a SCSI port on them for some regulation, and it was touted as a useful feature on the box and manual.
But I dont know where you might get the firmware to activate the port, in very much the same way as the Sky digibox CI slot
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
The user guide does mention that it can be used 'For a CD-ROM player or other high speed data equipment'.
Download user guide here...
_http://www.nokia.com/cda1/0,1080,1947,00.html
SCSI drives are older (now mostly IDE) and they are more expensive, may be worth a call to Nokia before you try one.
Appreciate that CH, got one sat on the floor here. :) I'm sure someone told me that you could use to flash software with DrOverflow though.
gameboy
Ding Dang Doo
www.gamezplay.org
Scotland
A quick Google search will agree that you can load firmware using the SCSI option.
Most are not in English, haven't found any that mention connecting a HDD for recording.
Burnham Beech
You can buy old PCI scsi cards very cheaply from eBay. The connecting cable will cost more than the card. You need the PC near the Nokia as you can't get long scsi leads.
Then use programs like DVBrecorder to record to your PC's hard drive. It's a big subject. I suggest your read through no-access.de site for the detailed information (the Hardware section is a good place to start) as there are many pitfalls.
Low Profile
DM800HD, DM7000 80GB HD with Asus WL330 wifi + 2GB usb drive, Skystar2.3, 2.2m Kinhuge Dish with Inverto LNB and Invacom ADF-120 feedhorn. Pace 1.3.25 and 80cm for Sky.
Lot, Dordogne, Correze border.
An alternative would be to use ProgDVB with the 'nokia plug in', the advantage of this is that in theory you could simply add an emulator in the ProgDVB root directory and decode using the latest keys. Whatever you do I would recommend Windows 98 as the most compatable O/S.
