Nokia 9800 Tuner replacement
Turok
1,25 Fibostop
Jäger Smr 1224 & Smo 36 Dual Axsis Motor
Dynasat F1
Monterey 140
Drembox 800
sky Pace HD Box
Tagra 2,20 M Fullsize Dish
Echostar 2,40m Mesh for cband!
Austria
hello!
yesterday,my 9800 is crashing from the table,and the lnb input of the tuner is broken..
so iam looking ,for a single ,tuner @ the moment...
is it dificult to replace inside?
Hello,
Because you get no answer until now, here is mine.
Usually it is easier to repair the F-connector on the tuner than remove it from the main board.
You need to remove entirely the main board from the cabinet, so you can open the tuner.
