Have a look on http://www.modshack.co.uk/forums/index.php?s= , there is information about it there. Be aware that it requires making alterations to your cable box, some which are not easily reversed.
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
I'd like to give you a little advice, if you don't mind and the best way is by drawing your attention to Channel Hopper's posting via the attached link. http://www.satellites.co.uk/php-bin/forum/showthread.php?s=&threadid=3364 I'm not moralising on the issue but merely pointing out, factually, that defrauding NTL is a crime for which the penalties can be severe. So it's probably best not to advertise the fact especially since a call to BTOpenworld would identify you.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
