I.LuV.ManUTd!
- 80cm motorised with quad LNB, static 28.2E with quad LNB, VU+ Duo, DM500S, DM500S, DM800HD, Openbox S9.
- Manchester
My dreambox died and I need to reflash it using a Null Modem Cable. It is stuck in a wizard loop (TV System, Language etc.)
I've been told that the Null Modem Cable is not the same as a Serial or RS232 Cable.
I was searching Maplin and I found these two products:
_http://www.maplin.co.uk/serial-null-modem-9-pin-female-to-9-pin-female-97740
_http://www.maplin.co.uk/usb-to-serial-9-pin-male-adaptor-29968
Would these two work in flashing my dreambox using DreamUp?
